new feature Workgroup Manager
ptc-3797114
I have tried to connect IsoDraw to PDMLink. This should work since 7.1 F000. After installing IsoDraw 7.1 F000 and Workgroup Manager 9.1 M020 I have chosen to register the application 7.1. In Workgroup Manager it is possible to connect to the server. Isodraw shows one new dropdown menu "Ext", which can not be opened. Anny suggestions what is wrong? Or where I can activate it?
Hi Gregor, the EXT menu is always visible and is not related to the UWGM. It contains IsoDraw plugins if some are installed. Usually after registering IsoDraw on Windchill, additional toolbars should be visible (check in, check out, etc.) You may restart IsoDraw and check the preferences. There is one pane where a check mark should be active, indicating that you are connected to Windchill. If all this is given, the connection to Windchill should work. If you still have no success I recommend that a specialist from PTC support helps you further. Much success, Christian
The Pane is available, but completely greyed out...
Gregor, I recommend that you contact PTC support for guidance to solve that matter. regards, Christian
