_nolinebreak in gentext
JeffStevenson
Hello everyone,
I'm working with Styler 6.0 M050. I'm looking for a way to use the _nolinebreak PI within gentext. Since PIs are stripped in gentext, I cannot find a way to retain this PI. I cannot find a _nolinebreak equivalent within custom touchup.
If anyone has any thoughts on this, it would be greatly appreciated. Thanks!
As an addendum to this. I'm not speaking of adding the nolinebreak as PI in the context in Styler. The tech editors often add the PI in Editor in specific cases. This is where the PI is being stripped.
-Jeff
9 REPLIES 9
Hi Jeff--
I think you are trying to insert some generated text, where the
generated text doesn't break across lines. Is that right?
In that case, I think you will want to use a UFE to handle that. The
general approach goes something like this:
* In your regular element context where you want to insert the
gentext, insert a UFE surrounding it. In other words, your gentext
should be something like this:
o <_ufe:noBreak>My generated text that should stay
together</ufe:nobreak>
* In the definition for _ufe:noBreak, on the Breaks tab, click
Keeps, and set "Keep element content together" to "Yes", and set "Keep
scope" to "on same line".
That should do it, if I understand your use case correctly. (If not,
please feel free to clarify.)
--Clay
Clay Helberg
Senior Consultant
TerraXML
Hi Clay,
I'm pulling content from another element into the generated text. I need for the element content to keep from breaking.
So assuming I'm pulling element <section>
<section>
</section>
I cannot apply a global rule. The editors want some of the content to keep together and allow other content within the section to break. This was rather easy in 5.3 since _nolinebreak wasn't stripped out in generated text. Now, I'm having some trouble getting around the new 6.0 functionality.
I don't think you can insert _ufe's in to the main XML stream. I could be wrong.
-Jeff
Hi Jeff--
I'm sorry, I still don't follow what your use case is. Can you please
clarify with a concrete example of source XML, and what you want the
output to look like?
--Clay
Clay Helberg
Senior Consultant
TerraXML
Hi Clay,
For example...
If I have an element <meta> with gentext that is pulling content from element <section>, they need to keep various part of <section>'s content on the same line, but allow other parts to break. The default is for all content to break to it's own line.
<section>
Here is text.
Here is some more text.
Additioinal content.
</section>
The default is formatting is...
Here is text. Here is some more text.
Are PIs your only option for markup to indicate that the content of the "p"
elements should be inline, rather than block? What about some type of
wrapper element, or an attribute? If PIs are really the only option,
perhaps you could put a non-Arbortext singleton PI into the second "p" to
indicate that it should not break onto another line.
As long as there is something to identify that different formatting is
required, you can setup your style sheet to act accordingly, including
establishing contexts that will format material differently when it is used
in gentext than in the normal flow.
-Brandon 🙂
On Tue, Sep 25, 2012 at 11:30 AM, Jeff Stevenson <
jstevenson@gpslsolutions.com> wrote:
> Hi Clay,
> For example...
> <section>
Here is text.
> </section>
> Here is text.
> Additonal text.
> However, they may want to keep some of the p's on the same line. In 5.3,
> we could add nolinebreak PIs around the
's that needed to be kept
> together.
> <section>
Here is text.
> </section>
> This would yield the following formatting within <meta>.
> Additional content.
> In 6.0, the nolinebreak PI is getting suppressed in gentext. I'm looking
> for a way to allow the editors to add these nolinebreak regions as needed
> that won't be suppressed by Editor.
> Thanks,
> -Jeff
Hi Jeff--
This seems like a really strange usage to me. Perhaps there's still
something I don't understand about it. But what is the advantage of
Hi guys,
I was trying to avoid modifying the DTD, but it looks like that might be the only way to accomplish the formatting.
I'm unsure why the content in the p's are separated or need to remain separated. I'm trying to reproduce the environment in 6.0 as closely as it was in 5.3. This is being driven by an upgrade.
Does anyone know how to define custom touchup PIs? PTC allows to up to 9 additional custom touchups (attr1 - 9). I can't see in the docs how to define these other than they are defined within ACL. Has anyone defined these before?
I'm trying to leave DTD mods as a last resort. Although, it's sounding like the easiest solution.
Thanks for the help!
-Jeff
In Reply to Clay Helberg:
Hi Jeff--
I have used the additional attributes on touchup but only via ACL. I'm not
sure if there is a way to "define" them other than to code both the writing
and reading (whether by stylesheet or more ACL).
On Tue, Sep 25, 2012 at 11:19 AM, Jeff Stevenson <
> Hi guys,
> these before?
> -Jeff
> Hi Jeff--
Jeff,
Since the DTD already has the attr1-9 defined, there is no need to modify the DTD. If you want the user/writer to see something on the Editor screen OTHER than attr1-9, you can use an alias through the dtd.alias file that is initiated through the instance.acl file within the doctype folder.
To get something on the screen to respond to your selection of one or more of the attr1-9 attributes, you code the stylesheet.
With that said, I tend to agree with Clay. The separate lines you're seeing I believe are from the
coding. The PI's are not able to 'disable' the line breaks that are generated within the
tags. You'd have to have an attribute on the
tag that would give the ability for the stylesheet to react on that particular
tag by not producing a new line after the tag.
Good luck,
Bob
In Reply to Jeff Stevenson:
Hi guys,
-Jeff
