"Trevor Hendricks" wrote:
2) You can only export once without opening the text file back. If you attempt to export twice in a row, you will end up with a text file that will not update the original file.
. 3) Open original iso file, run batch that then opens the text file (while the iso is open). This updates the original iso file. Add a save command to the end of the macro if needed.
Make sure that once you open your original iso file you are using the "open" command to apply the alterred text file. Example: Open "C:\temp\alterred.txt" "Text_Excerpt"
