How to resolve printServices4-0.styler and printServices4-0.genfos file out of date or re-exported Arbortext Editor?
Gareth is correct, someone has made a change to the stylesheet. If you open the style sheet and save it again, then under file choose update stylesheet for editor. This will update the genfos file and should make the error go away. Also, if the stylesheet is at an older save than the genfos file it will also give you that message.
I have put in an enhancement request that when you save the style sheet it automatically updates the genfos file.
Bryon
From memory, the .genfos file is actually compiled from the .styler file. I think you should be able to delete the .genfos and then the system will re-generate. Test that out first 😉
Bryon
