"A required resource was unavailable"
azibuck
I'm helping a co-worker with a weird problem. When she tries to open an xml file, she gets a popup that says "A required resource was unavailable". The only option is to click OK. You need to click that three times, then the file opens but it looks bad. You can't see the elements. The attached screen shot is from a table but the whole think doesn't look right. The odd thing is, I (and others) can open that file without incident. It doesn't seem to be the .wcf file as I replaced hers with mine but that didn't help. I've looked at a bunch of settings and views but can't make hers correct, and I also can't get my good display to look like hers. Any ideas?image002.png
0 REPLIES 0
