We've just gone from 5.3 to 6.1 M030. I was not allowed to access the release notes on ptcusercommunity.com ("Account not authorized"). Does such a "differences" list exist in an accessible place?
Mic
Do you have access to the PTC support site?
Select the Arbortext tab, and then on the right hand side down under "eSupportTools" there is the link "Evaluate Releases with Update Advisor".
This will list the fixes made from the selected versions.
Also under "Quick Links" there is the link "Reference Document". This allows you access to the release notes of the different versions and there is a link to the Help Centers.
There's no "eSupport Tools" anywhere on the page, nor an "Evaluate..." anything. I'm also unable to access the Reference Documents page without upgrading my account, which requires a Global Support agreement purchase. I'll have to check with the appropriate department here at work to see if we've purchased this support agreement, but in the meantime it seems totally absurd to me that I can't even access the release notes without purchasing a support agreement.
I think I've found a link (through Google) to the Update Advisor, but again it denies me access.
Hi Mic,
The link to the Update Advisor is:
https://support.ptc.com/appserver/cs/update_advisor/update_advisor.jsp
You do need to have a PTC login though, but that should be sufficient.
Thanks, I did take a look at that, but I'm hoping for something more... human-readable, if that makes sense.
Hi Mic,
Please find the documents interesting you in the attachment.
Thanks, Vladimir. Looks like a lot of the same info produced by the Update Advisor, but presented in a more orderly fashion.
