repeated table legende in xsl fo
I match XML files to obtain pdf by using XSL FO.
These files contain very big tables (my < table > contain many < row >) exceeding a page.
I would like to recopy the title () of my table on each page where we see a part of the table.
If somebody understands me and can help me, thank you.
Xavier
Tags (2)
Re: repeated table legende in xsl fo
Laurence Picot wrote:
> Hello,
Just put the title in the table header, e.g., as a separate row with one
cell that spans the width of the table.
Cheers,
Eliot
W. Eliot Kimber
Professional Services
Innodata Isogen
9390 Research Blvd, #410
Austin, TX 78759
(512) 372-8155
ekimber@innodata-isogen.com
www.innodata-isogen.com
Eliot's suggestion is a good one.
Alternatively, you can investigate an Arbortext
extension that allows floats to be scoped and
repeated at page breaks; see
> > Hello,
> > thank you for your answer, but I don't understand how it works. I use
the version 4.4k and my file xml contains < table > containing a .
> > If it is possible, would-you have an example of use of this extension,
or an explanation?
> > Thank you
> > Xavier clouet on behalf Laurence Picot
