Has anyone else discovered a problem with attribute tests run against lots of elements that control the Edit Window display after upgrading from 6.0 to 6.1? Specifically, I am encountering intermittent crashes (some "unhandled exception" failures, some segment 11 failures) triggered by screen highlighting of profiled content. For example, I want the following to be highlighted red:
<para book="first">blah blah blah.</para>
And this to be highlighted blue:
<para book="second">waa waa waa.</para>
And this to have no highlighting at all:
<para>all work and no play.</para>
I had a user report an unhandled exception crash opening a particular document. I replicated the issue. I chased the code and could avoid the crash by disabling the FOSI call (via system-func). However, when I tried opening a very small chapter from this same document, while the code was enabled, the chapter opened fine. Then I tried opening the whole document and now I can't make it fail. I sent the chapter excerpt to my author but won't hear back until Monday whether that "magic" fix is a fix at all for her.
Anyhow: Has anyone run across anything like this in 6.1?
We are in the process of upgrading from 6.0 m090 to 6.1 m050.
