set line length using FOSI and Styles
Highlighted
Newbie
Yan,
Do you want the line on the screen in Editor or in your output? The
answer is no and yes. Help 568 and the following example should help you
set this up.
<ruling thick="2pt" lentype="spec" speclen="10pi" voffset="25pt" placemnt="&lt;br"/>"after">
Now you can place a rule on screen, it will display within the edit window
as best it can. To specify a given number of characters, no, but you can
set it to a publication measure that would equate to 80 characters based
on the font size.
Lynn
Tags (2)
