We have this problem with importing illustrations as a png in Arbortext. It seems like when you import a png illustration it somehow saves the size of the illustration. If you go back and change the size of the illustration it seems to use the old size and tries to fit the new illustration in the old size. The size is then usually too large. The only way we seem to be able to size the illustration is after one has been imported is by trial and error. It can take hours and days and we need another solution to this problem. ANY help would be appreciated.
