styler or stylevision
Highlighted
Newbie
What is the better tool to create stylesheets: Styler (Arbortext) or
Stylevision (ALTOVA) ?
Kind regards
David G
INTERFACE
Tags (2)
Highlighted
Re: styler or stylevision
By "stylesheets", do you mean XSLT or XSL-FO or FOSI? If you are
talking FOSI or FO for output, and Epic Editor is your normal editing
and output source, it is probably better to use Styler, which is more
closely coupled to Epic. You would be able to better and more quickly
see the results of your efforts.
For the same reasons, if you are talking XSLT, I like to use XML Spy,
another Altova product. I don't know anything about Stylevision, but
if it is similar to XML Spy, it might be better for XSLT. XML Spy
allows for the immediate gratification of your XSLT editing efforts.
However, like I said, I don't know anything about Stylevision.
