supporting 64 bit
MattProwell
supporting 64 bit
Does Isodraw 7 support 64 bit os
Hi Matt, there is currently no native 64 bit version of IsoDraw available. However the 32 bit version can be used on 64 bit plattforms. Regards, Christian
If you use the 32 bit version on a 64 bit platform, does this get over the memory problems when using large 3d files in CAD process?
Hi Tim, that would demand a 64 bit version of IsoDraw. All you can do now is setting the 3GB switch on your 32 bit OS to use more memory. regards, Christian
we have some 64 bit machines (windows xp 64 bit edition running on 2x Quad core zeon CPUs). I have found that if accessing a website that has cgm content using isoview as a viewer, if the site uses a frame or iframe to show the drawing a blank screen is displayed. But if mime type or clsid are include in the webpage code (via embed or object tags) the drawing is displayed. example code: <embed type="application/x-isoview" src="abc.cgm" border="1" width="400" height="300" view="Start"/> <object id="ivx" classid="clsid:865B2280-2B71-11D1-BC01-006097AC382A" src="abc.cgm"> </object> is there a known fix or workaround for this issue we are using isoview 5. thank you for your time.
