Paul,
A small detail I'd like to point out is the use of variables in a command line window. Generally, you have to put the command "execute" before each of the addtional commands in the command line. Otherwise, the value in the variable is the value set the last time the varialble was hit, not this time. That can cause the apparent "lag" in the response, or the one behind response.
In your example of the Concatenated commands to report break_penalty status:
$oid = oid_caret();$cell = tbl_oid_cell($oid);$row = tbl_cell_row($cell);tbl_obj_attr_get($row,"BREAK_PENALTY",$break_penalty);response('$break_penalty = ' . $break_penalty);
In order to get this to work right "now," you have to do this:
$oid = oid_caret(); execute $cell = tbl_oid_cell( $oid ); execute $row = tbl_cell_row( $cell ); execute tbl_obj_attr_get( $row,"BREAK_PENALTY",$break_penalty ); execute response( '$break_penalty = ' . $break_penalty );
The result of thecommand line is to evaluate each varialbe with the current values of the variables involved, not what they were the last time.
Hth,
Bob
