Just a line separating the thead from the tbody. I do not want the writer to
change the content (rowsep="1"), but rather have it match the print FOSI,
which default behavior has the line. As I walk around I notice writers,
adding rowsep attributes to display the line, but since the print FOSI does
it already, it adds no value to have the writers add it, except to make it
pretty on the screen. Our print engine is DL Composer, so the print FOSI's
are not interchangable with our screen FOSI's, even at the table, thead,
tbody areas.
I could change the background color, I do that now if the writer has
multiple thead rows the background is changed to red, (sort of an error
check), but that is not what I would like.
Also, I am not interested in changing anything in the DTD's, because this is
really just eye-candy for the screen.
d
