I am working with Editor 5.4 and print composer using the MIL-STD-2361D 45001-2A stylesheets. I have a customer's comment about single line notes, warnings and cautions that says the mil spec needs these single lines to be centered, but the stylesheet formats all <trim.para> the same: indented from both margins and quad left.
I've tried inserting a custom touchup - 1) around the text within the <trim.para> element and also 2) around the <trim.para> element itself to override the quad left alignment but either way it is ignored and the line composes indented and quad left. I know the stylesheet respects some touchups because it allows me to put in newpage touchups with no problem.
Example of markup:
<note>
<trim.para>Testing note alignment override for centering.</trim.para>
</note>
Can someone point out to me what I'm doing wrong here? is there some other solution or is this not possible?
Thanks, KM
