I got a new computer and loaded Isodraw onto it. How do I go about transferring all of my preferences files (pens, libraries, etc) from my old computer to the new computer?
On your old computer look in the C:\Users\userid\AppData\Roaming\PTC\IsoDraw\ folder all your user defined stuff is saved here.
Bryon
Bryon
Did Bryon's suggestion resolve your issue? If so, then could you indicate that it is the correct answer?
This will help the Community identify useful threads.
Yes it did. It gave me the folder path to look for
Then mark it as the "Correct answer'.
