Do you need to export this file for every iteration of stylesheet? We have four stylesheets that are basically identical except for the cover page. That the stylesheet publishes.
Bryon
Hi Bryon,
If your four stylesheets are essentially the same markup, all four stylesheets can reference one set of .xlf files and they all go in [application]\lib\locale\[language]\sma_gentext.xlf (if using Sevice Manual Application).
Jerry Tippie
