I will try my best to explain.
I have a ditamp that has torques specifications in it. I wanted every manual to have the same info in the same order. The way that was figured out to do it is to create a topicgroup in this ditamap and then reference the topicgroup from each ditamap. Seems to work well.
I now have a user that wants to create a xref to the torque specifications section. When we create the xref, big red letters state, missing cross reference text. When we publish it, is says the same thing. I expect this is a style sheet modification but need some guidance.
Bryon
Thanks for the response, Is there a way to do what I would like with out making any modifications?
Bryon
Thanks, for the help Chris, I am very slow with styler. I have a document open with a xref that works and an xref that does not work. When clicking inside either xref, they both take me to the same context under the xref element. xref everywhere else is highlighted green. Do I need to add a condition? or does it need to done at the same level as other contexts under the xref eleemnt.
xref[@type='topicgroup'] If I create a context like this do I need to give it conditions
Thanks for your time and support
Thanks for the response David, that we what we will do.
Bryon
