I´ve got problem with 3D mouse SpaceMouse Wireless. When I´m using Creo Parametric 3.0 and I do some work in assembly...like activate one of models...do some changes...regenerate, it will appear a Selection "Part" so it is impossible to do more changes on active model. I must change selection by my hand to "Smart" and then I can work. It is happening all time.
Another thing is when I don´t touch 3D mouse or unpluged it from computer - then it is no more problem and I can work in "Smart" all day.
3D mouse is very good tool for me, and I don´t want to give up it
Thank you for any response.
Ondrej
I found similar problem reported on 3d Connexion Spacemouse Pro // Active Filter PROBLEM page.
If your mouse worked well with Creo 2.0 and now is causing problems with Creo 3.0 then:
MH
I start using 3D mouse with Creo 3.0.
PTC Support told me, "we don´t know about this problem". That is why I desperately looking for any help anywhere.
I can reinstall driver, but I have worries about my MapKeys which I´ve got tagged in my software.
What do you think about saving MapKeys?
Ty.
Ondrej
I am sorry, I do not have any experience with 3D mouse and its configuration (i.e. MapKeys assigned to its buttons).
MH
to make a backup of you settings you need the following folders:
C: => Users => [Username] => AppData => Roaming => 3Dconnexion => 3DxProENGINEER
C: => Users => [Username] => AppData => Roaming => 3Dconnexion => 3DxWare
You can find the mapkeys at 3DxWare\Cfg\[App]
Hope this helps.
Fred
Thank you Fred, I will reinstall driver tomorow with IT man. But my hope is really small because like I see, I´ve got already latest version of driver installed.
We will see. Many thanks for routes to backup. This information I´ve got from PTC Support, so it is right.
OK
Hello gents,
Yesterday I reinstall mouse driver, but without any changes. Even I try to use second device what we got at the office but It is still the same.
I´m desperate.
Andrew
Hello Ondrej,
I tried to find the case with Technical Support about this issue, but I could not find anything in our database.
Did you open it on behalf of someone else? Can you provide me the number to check, what went wrong.
I find it strange that the answer should be simply "we don´t know about this problem".
The TSE should either find that it works when (s)he is testing it or - in case testing is not possible - refer you to 3D Connexion.
This is because it is their hardware and their software (based on our Toolkit API) that makes it run. If there is a problem, they would take care and if a solution requires PTC, they usually approach us. But we try to help, if we can.
Gunter
Hello Gunter,
Sorry for my late answer.
We have got 2 devices, but noone from office didn´t work with this mouse. I think a tryed even a second device.
What number you mean? PID of device is A4314151424, P/N: 3DX-600044.
Great day,
Andrew
