3d connexion mouse to control assembly components?
ptc-2559830
I currently use a 3d connexion mice to move around in 3d space. I've notice that the mice can only affect movements to the world coordinate system and around arbitrary points in space. What I would like to do is control a assembly component with the 3d mice and if that component is part of a mechanism, it would update the mechanism joints in real time. This would be very similar to the component drag tool but instead of using a standard mouse, you would be using the 3d connexion mice to affect movement.
Is such thing possible?
Thanks!
0 REPLIES 0
