Hi all,
I'm working on a framework where all tubes have to be replaced by an other tube...
Can that be done by some simple changes/instructions or all need to be redefined by AFX?
Re-assign new profile and regenerate or ....?
>>> 30x30 profile was used, now it needs to be 50x50
If I edit the extrude in each tube, my positioning by AFX is not ok anymore
Didriek
here is the Quick AFX/EFX (Expert Framework Extension) video tutorial for you
Hello Didriek,
just got to profiles dialog, go to tab modify then select the size 50x50 press replace by new instance button and then select the profiles which shall be changed to 50x50. To update profile movements relative to curve you go to tab move of profiles dialog and then press button update profile move (4th button in first row)
If you have more questions just contact me at stefan@buw-soft.de.
I also can give you AFX training guides if you need them
Stefan
