Has any one ever needed to report the wight of wire in an assembly? How do you wight to a cable. Most wire I've come a crossed give lbs/ft, how can i add this in to be calculated with the assembly?
Chuck,
The wires will need the parameters "density", "units", & "mass_units". density will be a linear density ratio in mass/length (LB/INCH), units will be INCH, & mass_units set to LB. This should add the wires mass to the model.
jef
Chuck,
jef
Thanks Jef, that worked.
