Hi, i am having an assembly , which needs to be pattern following oval curve. when i tried to constraint assembly and pattern it. it goes away from curve on one side. any suggestion how to constraint and how to make the pattern to follow curve
Hard to comment without reviewing the data. However there is an article CS25579 for common curve pattern feature ... this may add some idea.
