Assembly Cutouts
JWayman
Assembly Cutouts
Folks,
I need still more help.
It appears that Insert, Shared Data, Cutout from other Model can only be
used to cut out the outline of a part from another part. Unless I am
mistaken.
What is the recommendation for cutting out the outline of a sub-assembly
from an assembly? Imagine a mould tool that, itself, was a welded assembly,
being used to cutout its shape from the moulded bit, which might have had
some threaded inserts cast into it at an earlier stage, for example.
Wildfire 2, m220
0 REPLIES 0
