Frequently I am getting assembly warning with yellow indication (out of three Green, yellow and Red) in the Assembly status. After re-generation, it will turn to green. I will save the file and close the PTC Parametric window. Once I reopen the file, the Assembly status will again go back to yellow. What are the possibilities of error I am doing in Assembly. Can anyone in the Community help me out few tips to fix the issue?
I found this with .prt's & .asm's. See if this helps:
https://community.ptc.com/t5/Part-Modeling/Regenerating-Family-Table-Instances/m-p/591305#M31509
Possible points:
1. Relations in assembly or relation in part
2. Any User Inputs (Pro/Program)
3. Specific component or set of components might be causing this.
- This may need hit and trial by removing/Suppressing some components to check if this is due to specific set of files.
