Assembly chamfer and round
Participant
In Creo we can not create chamfer and round in assembly level. Still that option is available in assembly. Why is that ???
10 REPLIES 10
Highlighted
Re: Assembly chamfer and round
Mine are grayed out in Creo 2.0 M040. Maybe they are available for advanced assembly features?
Highlighted
HI,
just wanted to know is Creo 2.0 M040...working fine. have you found some bugs?
Highlighted
M040 seems to be fairly stable.
Highlighted
just reported a bug yesterday in Creo 2.0 M030 sketcher. the offset and thicken option do not highlight the chain under the chain option within the same sketch.
and offcourse..the issue with save a copy of assembly window...for which they have been saying that i have to increase the resolution my screen.
Highlighted
There is already an SPR files for this in M030. There is no resolution date attached as yet.
Highlighted
HI,
you are talking about the offset sketch or save a copy assembly window or both?
Highlighted
The highlighting thing...
SPR Details - 2169070
https://www.ptc.com/appserver/cs/view/spr.jsp?n=2169070
Highlighted
yes that's correct....the techincal support has emailed that to me.
actually the save copy assembly window..is the major problem...
Highlighted
Because we can do sketching in assembly and we can use many other tools in that sketch.. chamfer and round are 2 of them
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
