Assembly constraints & copy geometry not updating
Highlighted
Aquamarine
I'm having a strange behavior in CREO. The copy geometry in assembly context isn't updating. The automatic update option is enabled. The regenerate doesn't update. The copy geometry only updates if edit definition and accept (no need to change anything). It's not in all parts, but I can't see any differences between the ones That is working, or the others were isn't working.
In a specific assembly, the constraints are also not updating. I need also to edit definition in the first part of the assembly, and constraints regenerates.
What can cause this behavior?
