Assembly constraints
Level 7
Is there a way to view all the constraints made in the assembly at one place? Like we can view all the csys, datum planes through the layers options.
1 REPLY 1
Highlighted
Re: Assembly constraints
i don't beleive there is any OOTB UI element or method that does this. you can file an idea if you think you have a use case of specific merit.
