Assembly questions
eonyenwere
Assembly questions
Please does anyone remember how to open a separate part window in an assembly model, A small window for the active part being assembled that comes up on the assembly screen, it helps to make it easy to pick features in a part where their is a cluster in the assembly.
1 ACCEPTED SOLUTION
Use this button in the dashboard.
In the model tab, select assemble, <select the component/assembly>
a new tab will open - component placement
there will be two window icons toward the right side, select the first one.  this will open the component in a seperate window
cp2, M180 with ootb menu
ron
Hi Emmanuel,
Did one of these responses answer your question?  If so, please mark it as the Correct Answer, to close the loop and provide a solution for other users who may search for the same question.
Amit
Thank you all. (Gary, Ron, and Amit). your answers rightly answered my question. I had been playing with it for a while and kind of stumbled on the answer by myself but thank you guys anyway.
Emmanuel.
