Assmbly cut - thread still showing in removed material
SOLVED
Highlighted
Topaz II
An assembly cut is being made on one end of a part. That end of the part had two tapped holes. Now that the material has been removed, the threads are still showing (suspended in air). Shouldn't they be gone?
Thanks, Dale
1 ACCEPTED SOLUTION
Re: Assmbly cut - thread still showing in removed material
Nope, those are solid cuts.
Have a look at this workaround on the drawing:
Hide cosmetics in drwhttp://communities.ptc.com/message/261764#261764
4 REPLIES 4
Highlighted
... but if the threads aren't there, then why are there cosmetic threads?
Highlighted
The solid holes aren't there but solid cuts don't affect the cosmetic surfaces.
Highlighted
David Schenken does that mean I need a cosmotologist to make a cosmetic cut?
