AutoGEM Mesh creates error: This shape change invalidates the highlighted bearing loads?
danderson
11-Garnet
Good Afternoon,
I'm trying to mesh an assembly and I receive the following error message:
"This shape change invalidates the highlighted bearing loads. Please delete the bearing loads if you want to change the shape of the hole."
I have no mesh controls in the model and I don't see anything that would cause the mesh to be incomplete.
The walls of the hole that the bearing load being attached to are parallel to the center line of the hole (not a tapered hole).
Anyone have any ideas what not allowing the model to mesh?
If I suppress the bearing load on the surface in question the assembly meshes fine.
Don Anderson
0 REPLIES 0
