AutoGem Fatal Errors...
pdkoren
I have an assembly analysis that will run just fine IF I create the mesh thru REFINE MODEL/AUTO GEM/CREATE, but will fail if I do not and simply run the analysis with default settings. I get a fatal error in the autogem section right at the start. When I do the mesh creation myself, I do get pop-up questions: "AutoGEM has detected problems adding elements to the model. Do you want these problems fixed?" and "Do you want AutoGEM to approximate all invalid elements? which I answer yes to both. Then I can save the mesh and letthe analysis use it. The problem areas are in a componentthat isnot critical and"inherited". I haven't spent the time to fix these areas. I am wondering WHY Creo would have the capability to"fix" AutoGEM mesh issues but not use them during a normal analysis run? Though, I guess I understandnot wanting to "magically" fix stuff without telling the user. BUT,am I missing something? IS there a way to tell theanalysis to do so?Just curious... sooner or later, I will end up fixing the problems areas...
Hi Paul,
There definitely is a way to have these errors automatically fixed, because I see these errors in my output files immediately followed by a 'Yes' - without my intervention. However, I'm not sure what setting has caused our setup to behave this way!
It may or may not be related to this general config option - it's only a wild guess:
show_geom_checks_on_creation no
HTH,
Jonathan
rgiles
(To:pdkoren)
Hi Paul and Jonathan,
I think the option you're looking for is:
sim_expanded_diagnostics yes
The default is no. Changing to yes makes AutoGEM automatically answer yes to any prompts during the meshing process.
Best regards,
Rod
Rod Giles
Principal Engineer - Powertrain CAE
Triumph Designs Ltd
Normandy Way
Hinckley
Leicestershire
LE10 3BZ
United Kingdom
