Automated Publishing Issue
Newbie
There is a known problem with republishing in Creo View upon check-in when a lower level rep or family table instance is swapped into an assembly. Is anybody aware of a work around for this issue? We aren't too excited about the prosepct of revisiting all of those replacement items and publishing each one of them as needed.
Thanks in advance.
RE: Automated Publishing Issue
Tom, can you give an example image showing what you are referring to? There are quite a few limitations in regards to simplified reps in the publisher. My interpretation of what you describe is in the attached picture for the simplified rep setup with family tables. Is it correct? Also need to know if you are publishing as standard, positioning assemlby or extended positioning assembly.
Bill-
The issue is that if I publish everything from a top level assembly and then replace a sub-assembly with a rep of that sub-assembly, it does not automatically publish...forcing us to revisit those items.
PTC is aware of this shortcoming, and has a work around...but they have not shared that with us.
I appreciate your thought on this.
-Tom
PTC's work around is called Positioning Assemblies. There has been a few
great presentations over the last couple years at PTC Live Global.
Lance Lie
Sr. Info Sys Technologist II
Global Business Services - Information Technology
Raytheon Company
714-446-2806 (office)
714-402-7858 (cell)
1801 Hughes Way
Fullerton, CA 92833 USA
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
Tom,
Most companies are using a parameter in the CAD assembly to trigger the positioning assembly type publish when the user checks in the model. We have the parameter added to our start assembly file.
You can run a quick evaluation as an organization admin or site admin using the following steps to manually have the WC publisher publish an assembly as positioning assembly or even extended positioning assembly.
