Avoid interference for IFX fasteners
Alexandrite
New Customer Idea:
"When I am adding screws automatically through IFX, the generated bolt nut is having interferences because bolt is modeled on major dia and nut is modeled on minor dia. I have an assemblies where I have more than thousand parts including screws and nuts. When I am adding screws through IFX and doing global interference check, the result is always filled with screw interferences, therefore it is difficult to identify real intereferences. Why dont PTC make the library model nut part with hole major dia and put the cosmetic thread as internal minor dia. I think in this method there would not be any interferences in library part."
Re: Avoid interference for IFX fasteners
This idea is valid for both nuts and screws. The solid material should not intersect with each other. The cosmetic threads shall show the outer shell.
We have no plans to implement this in IFX by default.
It is up to the customer to change the library parts.
You can use the IFX-Suppress command to suppress all IFX library parts before you run your interference check.
