BOM Balloons for simplified reps!
SOLVED
Re: BOM Balloons for simplified reps!
I have figured out the same thing only recently. but have added a table on the sheet showing the simp rep, named that simp rep. and then hide the table. it is outside of the drawing frame. the other bonus to doing this is that your table only shows what is in the rep and its qty. so if you have 50 washers of on number the table and balloon only displays the qty in the rep. ie 12.
Thank, this is exactly what i done and it worked perfectly
Does fixing the index allow you to redistribute quantities between balloons from the different reps?
