BOM Sorting issue
BOM Sorting issue
Hello All,
Yesterday I got a repeat region with filters, sorting and a priority
parameter to work in an assembly with parts. Know I have added a
sub-assembly and I can't get it to sort to the correct location even if I
update the region.
The following is copied from the sorting programming for our BOM's. As can
be seen, the BOM is programmed to sort first by priority number (a model's
"priority" parameter), second by part number (a model's "part no"
parameter), and last by title (a model's "title" parameter). This sorting
determines which models get what item number in the BOM. Thus can be seen
the importance of filling out all parameters in each model
&asm.mbr.priority Forward
&asm.mbr.PART_NO Forward
&asm.mbr.title Forward
Might any one know way I can't get a sub-assy to sort with the components?
Thank You
Matt Romero
Mechanical Designer
Plexus Technology Group
361 Centennial Pkwy, Suite 300
Louisville, CO 80027
