BOM file with path info
Highlighted
Regular Member
Hi Folks,
A co-worker asked me how to make a BOM listing of an assembly (from the assembly model) that included the path so he could see where the parts were coming from.
I know that I did this back in the pre WF days but cannot see any way to do it in WF2. I can get a BOM html file OK but this has no path info. Similar if I make a text file from the model tree itself. We do have the path shown in the ProE window of each assembly or part when you have that window open.
I looked in WF2 Help and am none the wiser. I see the following
Highlighted
RE: BOM file with path info
In Reply to:
You can do this with Pro/WebLink.
If you use this article as your starting point (sends assembly BOM data to Excel):
http://inversionconsulting.blogspot.com/2008/04/proweblink-sending-your-proengineer.html
Then change this line by adding "INFO" in the GetData() function:
appdata.params = new Array( "LEVEL", "NAME", "QTY", "INFO", "DESC", "PROI_CREATED_ON" );
Then add the extra 'else if' block in the GetBOMData() function:
if (appdata.params[i] == "LEVEL") {
model_array["LEVEL"] = appdata.comppath_seq.Count+1;
else if (appdata.params[i] == "NAME") {
model_array["NAME"] = model.FileName;
> else if (appdata.params[i] == "INFO") {
> var descr = model.Descr;
> model_array["INFO"] = descr.Host + "|" + descr.Device + "|" + descr.Path;
else if (appdata.params[i] == "QTY" && model == appdata.root) {
model_array["QTY"] = 1;
Your BOM in Excel will have extra stuff including path. Format as you see fit.
Marc
Marc Mettes
Visit My CAD/PDM AutomationBlog
Or, Subscribe to My CAD/PDM Automation Blog by Email
