BOM from Multiple instances of family table
NaveenKumarGong
1-Newbie
Here I'm getting problem with BOM in PRO-E WF5.0.
I have added parameter in assembly for multiple instaces. How to get that parameters into the BOM in the drawing. I've tried with "fam.inst.param" but there only name, ID and values are there.
How to add User defined parameters from family table instances.
Thanks & Regards,
Naveen Kumar Gongu.
1 ACCEPTED SOLUTION
Thanks for Reply.
I tried as per you said Vojtěch Mráz. But its not working.
I got answer. It will get by repeat region by "TWO-D" option.
Thanks and Regards,
Naveen Kumar Gongu.
4 REPLIES 4
Try following: &asm.mbr.parameter_name
Example: &asm.mbr.drawing_number
Thanks for Reply.
Thanks and Regards,
Naveen Kumar Gongu.
So you resolved your issue by using &fam.inst.param (the parameter you initially tried) in a 2D repeat region instead of a one dimensional repeat region?
Hello Gunter Koch,
Yes, first I've used One-D repeat region finally I've solved my problem using Two-D repeat region 🙂
Thanks and Regards,
Naveen Kumar Gongu.
