Cabling Question
cenglish1
Cabling Question
I'm just starting to learn cabling. I've created a 3 conductor cable and placed it into an assembly. However, the conductors that come out of the cable are going in the wrong direction and for the life of me, I can't figure out what I'm doing wrong. Please look at the attached screenshot and point me in the right direction.
Thanks in advance,
-Capel
8 REPLIES 8
Here is my cabling workflow.
1) Create a connector with one or more coordinate systems to be used as entry ports
2) Create assembly and add connector to it
3) Go into applications->cabling and create new harness part using the default template
4) Create a cable spool with 3 conductors; enter min bend rad and thickness
5) Enter bend rad and thickness for each conductor
6) Designate the connectors.
7) Define the entry ports (wire and round)
😎 Click route cables and create a new cable feature
9) Define the from and to entry ports for the cable
10) Define the from and to entry ports for each connector
11) Click ok
I’ve attached another picture with the entry port coordinate systems visible.
When I follow these steps, I get the conductors exiting the cable in the wrong direction. What am I missing? I can't find any way to "flip" the conductors so they exit the cable in the correct manner.
I've tried reducing the bend radius and moving the cable entry port CSYS further away from the wire entry port on the connector and reversing the Z direction of the cable entry port CSYS. None of these things had any impact on how the conductors exit the cable. I must be doing something wrong, but I’ve searched this forum and Google to no avail.
Any suggestions would be appreciated.
Minimum bending radius for spool seems to be set too high, you can try to lower that value.
Mehmet Ali Piskin
ASELSAN Inc.
MGEO Division
Cankiri Yolu 7.km
Akyurt
Ankara / TURKEY
Just a SWAG, but maybe it has to do with the distance between the
terminals and the cable exit point, and possibly the radius of the wires
coming out of it. I don't think you can control that radius, but may be
moving the terminals farther out will fix it.
Ken Sauter
dbowles
(To:cenglish1)
Your csys is reversed. Flip the EP_C so the Z is reversed
Douglas K. Bowles
Advanced Systems Harn/Des
520-665-7082 Office
520-490-9395 Cell
PRIVACY ACT NOTICE: This communication may contain privileged or other
Official information. If you are not the intended recipient or believe
that you have received this communication in error, please reply to the
sender indicating that fact and delete the copy you received. It is a
violation of Federal Law to print, copy, retransmit, disseminate, or
otherwise use this information without prior authorization.
With help from the guys at SW Research Institute, I finally figured out my problem. First, you can't use a 3 conductor cable and route it to 3 different connectors. I was trying to route the cable to a entry port (round) and the conductors (wire) to different connectors and nothing was working.
Here is what worked. 1) Designate the entry port (wire) on the 3 connectors. 2) Create a network route using points. 3) Insert 3 wires using the via network option. This routed all 3 wires correctly. 4) Create a bundle specifying the end points of the network route and a new spool.
I've attached an image if you are interested.
Thanks to all who responded.
-Capel
Capel
I do not know the full context of the mail but it is absolutely possible
to route the conductors of a cable to different connectors.
See the attached movie as an example
Hope that helps
Jim
Jim, very helpful and easy to follow.  Thanks.
Ok, I stand corrected. What I was missing all along was the right-click in the From/To selection boxes and getting the context menu that allows me to select a location. Assigning the cable to the entry ports (round) is definitely the wrong thing to do!
While bundling still works, the method Jim demonstrates is much easier...
