Camshaft problems
ptc-4786200
Camshaft problems
Dear,
For a schoolwork do I have to analyse the forces on a camshaft by Creo Parametric. But I have some problems with the assembly.
Like you can see on the movie there are 2 faults in the assembly:
Problem 1 :
The valve springs moves each time with the valves. How can I do it so that the lower part of the spring rests motionless when the upper part will be pressed.
Problem 2 :
Like you can see the cam goes through the valve guide. I’ve assembled this by using a “ cam connection” . The program pushes the cam each time on the centre of the guide so that the cam goes through the guide. Does someone knows how to solve this?
Thanks!
0 REPLIES 0
