Can Creo 3.0 M070 open solidworks 2016 files?... nothing happens when I try
rdrake
Hi All,
Trying to open up our vendors Solidworks 2016 parts and assemblies,  but nothing appears to happen... is there something that needs to be configured to get this to work?
Thanks in advance
StephenW
(To:rdrake)
No. https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS134024
Only up to solidworks 2015. This is normal for conversion type software, they can't keep up with the latest releases.
6 REPLIES 6
StephenW
(To:rdrake)
rdrake
(To:rdrake)
Thankyou !!
on 11-December-2015 I opened Case at PTC support - https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=12859749 (I think it is not viewable for you). I am waiting until now, because product manager responsible of this technical area is out of the office, and will be available on Jan 7th 2016.
MH
Martin Hanák
Refer to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS221689
unable to open solidworks (2015 service pack 5) file in Creo parametric 3.0 M060
  • Reported R&D as SPR 4887849
  • Fix committed for Creo 3.0 M080
MartinHanak
24-Ruby II
(To:yshen)
I think that Solidworks 2015 service pack 5 file format does not have be equal to Solidworks 2016 file format. What is your opinion ?
MH
Martin Hanák
lbai
(To:rdrake)
referring to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS229795, Creo 3.0 M100 import support Solidworks 2016
