Can Creo 3.0 M070 open solidworks 2016 files?... nothing happens when I try
SOLVED
Highlighted
Newbie
Hi All,
Trying to open up our vendors Solidworks 2016 parts and assemblies,  but nothing appears to happen... is there something that needs to be configured to get this to work?
Thanks in advance
1 ACCEPTED SOLUTION
Highlighted
Re: Can Creo 3.0 M070 open solidworks 2016 files?... nothing happens when I try
No. https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS134024
Only up to solidworks 2015. This is normal for conversion type software, they can't keep up with the latest releases.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
6 REPLIES 6
Highlighted
Steve Williams
Highlighted
Thankyou !!
Highlighted
on 11-December-2015 I opened Case at PTC support - https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=12859749 (I think it is not viewable for you). I am waiting until now, because product manager responsible of this technical area is out of the office, and will be available on Jan 7th 2016.
MH
Martin Hanák
Highlighted
Refer to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS221689
unable to open solidworks (2015 service pack 5) file in Creo parametric 3.0 M060
  • Reported R&D as SPR 4887849
  • Fix committed for Creo 3.0 M080
Highlighted
I think that Solidworks 2015 service pack 5 file format does not have be equal to Solidworks 2016 file format. What is your opinion ?
MH
Martin Hanák
Highlighted
referring to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS229795, Creo 3.0 M100 import support Solidworks 2016
