Can't Use ANSI Fasteners
Bob_Johnson
7-Bedrock
Hi all,
We have the full license for IFX. I have access to some catalogs (mm for example) but I can't assemble fasteners from the ANSI-ENGLISH catalog, which is what we use in production.
I get the below error:
I know that the ANSI fastener files are not stored in the common files/ifx/parts/IFX_fastener_data folder, but instead in the common files/ifx/parts/prolibrary folder.
What setting do I change so that I can use ANSI-English catalog fasteners?
normaly this creo option should be set by default.
Please have a look to "C:\Program Files\PTC\Creo 6.0.3.0\Common Files\text\config.pro"
There you should find the necessary option:
search_path_file $CREO_COMMON_FILES\ifx\parts\prolibrary\search.pro
Oli
Oliver Gräbner
B&W Software GmbH
Oli
Oliver Gräbner
B&W Software GmbH
