Hello Colleagues,
I am sure this has been addressed previously, but I cannot remember the answer....
My users want to move the message bar back to the bottom of thewindow instead of the top. I thought this was possible in WF5 but am getting mixed feedback.
Any insight would be useful.
David T. Francis
Stefan,
The config.pro option that Ronald mentions is:
A quick example:
pro_format_dir wtpub://My-server/Libraries/ProE Standards/Formats
This should ensure that formats no longer appear as new files in a user's workspace. Once this is set, you could also simply get rid of the formats from the local (or network) drive location.
One important note; make sure the server name matches that used in the server registry (or server manager) within Pro/E, including case sensitivity. I haven't tested in awhile, but once upon a time having the name different, or even having it capitalized incorrectly, would cause problems with this config option.
In Reply to Ronald Grabau:
Stefan,
Formats are a separate file. There will always be 3 parts to a drawing. 1. The drawing file, 2. The format file, 3. The model file.
So when you have formats on your local drive and you have them part of your template, it is going to open that file from your local drive. If you have an Intralink session, it thinks that you are importing a new version of the file and wants to make a modification. You don't want this. What you want is to set your path in your configuration file to point to your Intralink folder where the formats reside. This way you get the format from Intralink and not from the local drive.
By the way, if you allow your users to check out a format, you should change your policies. Users should not have the authorization to change formats.
I hope that this helps,
Ron Grabau
