Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Brief intrusion here.in case you are interested in our day-long spring event and haven't signed up please visit the link below.
We are pleased to have John Buchowski, PTC MCAD Product Manager speaking to our group this year with insight into upcoming features in Pro/Engineer Wildfire.
We are also very pleased to have noted Pro/E presenter Bart Brejcha flying in from Chicago to show us some surface modeling for die cast parts.
Of course, we also have most of the "local pros" that you have enjoyed in the past, presenting some of their (and your) favorite topics.
Lunch is provided but you must REGISTER or we might run out!
More info here >> This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
