Is it possible to change the plane in which an assembly is mirrored when using the command Mirror Assembly? And in that case, how can I controle it myself?
Thank you!
If u have mirrored the assembly and u want to change the plane without failing the mirrored object u have to refer the children parts i.e the mirror feature with some other plane. U can create a plane for the mirror
else, if u change the plane mirror will fail.
Hope that helps
I've set up a Product Idea regarding this so please vote: http://communities.ptc.com/ideas/3522#comment-11841
Here's a workaround from Doug:
