Checking Part Association?
Highlighted
Visitor
New user here. I am currently running Pro/Engineer Wildfire 4.0 and I was wondering if there was a way to check all the associated fiels a solid aprt was attached to.
For example if I used a specific part in mutiple assemblies and wanted to deleted this part completely, is there a way to see which assembly files the part is attached to before I delete it?
Thank you for your help.
1 REPLY 1
Re: Checking Part Association?
Hi
Unless you are working with Windchill or similar PLM software it is not possible to trace where a part is used.
You can only check if the assembly is in session.
For Example if you have opened a main assemly; then you can search in which sub-assemblies a part is used.
Regards
K.Mahanta
