Circular Pattern in Assembly
ptc-3074892
1-Newbie
Two parts made into an assembly .. one part needs to be copied in a circular pattern around the other, however, the pattern icon is not selectable .. how is this activated?
2 REPLIES 2
Your parts need to be fully defined using constraints. You then need to select the item you want to copy from the screen of from the model tree and the pattern icon should be selectable.
Great Joe, thanks. I'll check and make sure they were fully defined. That was prob it.
