Circular dependencies in an assembly
Highlighted
Newbie
Pro-Gurus,
First off, I hope this is the correct email group to send this question
to....
We are using Wildfire 3.0, Intralink 3.4
A user is trying to create a duplicate object of a large assembly for
layout purposes and is running into circular dependencies (see
attached).
What is the best way to go about correcting this issue? I have never had
the opportunity in the past to become too acquainted with circular
dependencies in the past.
Nick
Highlighted
Read the *.crc file carefully. It's not the easiest to read, but it
will tell you the path of features & components involved. I've found
that most of the time, simply re-ordering components solves the circular
ref.
Doug Schaefer
LinkedIn
