I have nearly a thousand parts in my large assembly. I'm trying to create groups inside the assembly. But it is very difficult for me to pick each part for a group in the very long model tree. I have to scroll up/down the model tree many times, pick the necessary components, drag them to a single place & then group it. It is a tedious process.
Is there any other way to create group by directly selecting parts from 3D window or by rule or any other way.
Thanks!
You can create group by selecting the components from graphics area, select components RMB > Group.. but there will be some conditions in this, as ... components should be at same level in assembly... and in between components will also part in group.
Is there no way we can by-pass the conditions? Like, somehow I can pick any parts in model tree irrespective of the level & components between them.
Thanks!
You can select multiple items that are not sequential and drag them in the tree. As long as you move one position they will all move to new position and all together. Any items that are also need to move do to relations will also move.
